3 Link Shock Questions?
  • High Tech Red Neck
    • Jun 2012
    • 3
    I've searched this forum and haven't found the answer to my exact question. I'm looking for experienced answers here so none from arm chair drivers or bench racers PLEASE.
    Running a 3 link b mod and we have to run a solid top link. I'll post my setup below. My Question is: Is it standard practice to run an easy up shock on the left rear when pinning the right front with a tie down? This car is was setup with a RF tie down and a LR tie down also!! That doesn't seem right to me. I really have to finesse the car into the corner so it will set and not push the nose. If I'm not in traffic I can get it to turn and burn but if I'm racing it's tough to get it to turn. Trail braking makes the condition worse.
    I bought this car used and have had several people tell me it was a good fast car......but you never know what your going to get. I didn't buy it right off the track so I don't know what parts were robbed or what was changed before I got it. The seller "said" that it was how he ran it.
    LF RF
    625 550
    3050 5030
    LF RR
    200 175
    5030 3030
    35 lbs of bite
    52.5% Left, 57.7% rear
    1/2" lead
    Chevelle clip car on AR G60's
  • mod 44
    • Feb 2009
    • 99
    you should have a hold up on the left rear
    • jsf74
      • 544
      The lr and rf are working aginst each other defeating the purpose. I run a 3-5 rf and 8-2 lr.
        • Jun 2012
        • 3
        Thanks fellas. The local speed shop had a box stock 3050 on hand. I'll bolt that on this week and see if it makes an improvement. It should!
