ford 9" question
  • imca90
    • Jan 2012
    • 51
    ford 9" question
    Whats the best way to check if my housing is bent without pulling it out?
  • johnny v
    • Mar 2011
    • 197
    I always used the axle and the floater drive plate..... If the axle is in a bind with the hub...... or not centered in the floater snout...... it's bent somewhere....
    see ya
    johnny v
    • Dirtrunner35
      • May 2010
      • 632
      Put the rear end on jack stands with the wheels on it and spin the housing and watch the wheels
      • imca90
        • Jan 2012
        • 51
        My left axle will not go in. But if i swap the drive flanges then the right one wont go in. If i loosen the flange so that it has a little movement in it then the axle slides right in. Is this a common problem with aluminum drive flange?
        • mod 44
          • Feb 2009
          • 99
          sounds to me you have a bent drive flange not a been housing i have had it happen got hit in the wheel at funny angle Just my 2 cents
