chaining the lr down
  • bluemod
    • 214
    Can someone please explain on where to start with chaining the lr. This seem to be the thing and am wanting to try it. Should I go from the frame to the bird cage or to the axle housein its self. How do i measure the chain to make sure everything is right. This is a grt car. If you could just explain how to do this. thanks
  • Darkstar15
    • 90
    Chain drop
    Measure the drop of left rear from sitting at ride height to jacking the car up in front of LR until the tire is just off ground. What you will measure is the difference in the chain length. We use from 4 inch drop to 4 3/4 in drop. You can also measure LUB angle as it will change as the drop changes. We measure from top of birdcage to frame rail directly above it. This is on a Shaw car.
    John
    • dirttrackrocker
      • Nov 2010
      • 664
      Chain it so the LRU bar can't go past 45 degrees.
      • johnny v
        • Mar 2011
        • 197
        don't hook it to the BC...... you can buy a floated chain hook up for the housing or make a 2 piece floated piece for the housing ( a bolt together piece for the housing means you don't have to pull the hub and BC to place it on the housing)....
        see ya
        johnny v
        • bluemod
          • 214
          So does the chain limit roll steer. Do you have to change bar angles or anything else besides add the chain and try it?
          • johnny v
            • Mar 2011
            • 197
            basically, yes, it limits hike and that limits roll steer......and it keeps you from using the LR shock as the limiter...or if you have an under-rail car, the frame rail hitting the housing as the limiter...
            the guts of your LR shock like limit chains....
            see ya
            johnny v
            • bluemod
              • 214
              Just to give you all some feedback. Chaining the rear down like that gave me alot more drive coming off. As soon as the chain catches you can stand on the gas and go. Thanks for the info tightened the car up a little but this was what i was needing.
              • johnny v
                • Mar 2011
                • 197
                your probably feeling this:
                sometimes if you have too much hike.... your using energy to push the frame up, not drive it forward.... limiting hike will put the drive forward... not up...
                see ya
                johnny v
