Going from a 3/8ths to a big 1/2
  • circle dirt
    • 742
    What spring changes if any should I make. Don't run too many 1/2 mile shows. 4 bar car with 225 lr , 200 rr, 750 rf , 700 lf. 1/2 mile is fast sweeping turns. Some say stiffen rr , others say raise top rr bar. Any help??
  • Flyin Iowan
    • 558
    What 1/2 you talking about ray? I change nothing but gear and stagger from tipton to west liberty, then make small changes after heat races to give the car what it wants but ill go with the same base setup for any track
    Chris Zogg
    • circle dirt
      • 742
      Osky. was wrong on rr spring , has 175. Last time there car felt like it was falling on rr and losing drive off
      • RUEF52
        • Oct 2008
        • 160
        Change gear GAS HER UP and GO! Might trail the RR a little.
        • RUEF52
          • Oct 2008
          • 160
          Replied before you revised your spring rate,I'd run a 200.
