I would like some opinions on running a 4 bar mod with more weight on RR than LR. My car is real loose off gas on entry. I have tried all different bar angles,springs, shocks, RR trail and RR lead combos, different brake adjustments, tire stagger, rear end alignment left to right, checked for binds over and over. It seems the best about 20 Lbs LR heavy. If I go higher than 30 Lbs Lr its really loose
but never good. I have never tried RR heavy I was looking for some suggestions of how much RR heavy to start at to try it. All the adjustments I have tried affected center and exit but never really cured the loose off gas on entry problem this car has had since new. Any suggestions or Ideas would be very helpful. We run UMP tire and J bar 5.5 inches of rake.
Thanks
Thanks
