problem scaling sportmod
  • millerracing
    • Aug 2007
    • 72
    car used to scale out fine normally 25 LR bite - panhard bar mount used to bo close to right frame rail (long panhard bar ) , now relocated closer to center of rearend with using shorter panhard bar
    was the change made now car scales out 50 + RR heavy , is that what im to expect from making this change ? went through the car front to back there are no binds bends or anything wrong
    with it
  • washeduptoo
    • 1353
    I'm guessing you did recenter the rear end to specs?
    • millerracing
      • Aug 2007
      • 72
      yes , just shorten panhard bar and were it mounts , the degree is still the same - i just never experienced such a drastic change on the scales like this , kinda curiose if anyone else has
      • tutt71
        • Aug 2007
        • 80
        I am assuming that the springs are mounted at an angle. If you shorten or lengthen the panhard bar just slightly it will have a drastic effect on static load at the spring. Changing the bar length will cause one spring to stand up taller and the other to lay over more. This will put more load on the spring that is "stood up".
