Can you patch a hoosier???
  • emodracer
    • May 2012
    • 101
    Just got a brand new D40. Ran it one lap and it got punctured about the size of a pencil on the sidewall. Can it be patched or does it need thrown out?
  • washeduptoo
    • 1353
    Patch it and put a tube in it, some put baby powder in tire with the tube. Good luck.
    • dillon_94
      • Dec 2010
      • 72
      you will spin the tube if its in the rear, should only use it on the front imo
      dillonsolumracing.weebly.com
      • dirty white boy
        • 1238
        take it to a tire shop that dose big truck tires,..have them put a "boot" in it,..its like a patch with a plug built in to it,..dont see how it couldnt work!
        white trash motorsports
        • dirttrackrocker
          • Nov 2010
          • 664
          I have done this in the tread area, but, I wouldn't suggest patching or repairing any tire on the sidewall.
          • dualdj1
            • Jun 2009
            • 654
            Agreed. use it with a tube for a front tire if you can.
            • Egoracing
              • 4852
              Sidewalls are bad territory as the tire is thinner and designed differently. I would use it as suggested with a tube but not on a high load area. Maybe the LF if you can and get the others to what you need.
              • emodracer
                • May 2012
                • 101
                I appreciate all the info. I looked at the tire closely today after washing everything and it is peeled back just a little and then on the inside is a pin size hole. Will prolly patch the inside and out and put a tube in it and see what happens.
                • andy90x
                  • 18
                  I patched a side wall once and after the tire heated up it blew up. It was like watching a NASCAR guy blow a tire and destroy the body work. Dont do it, not worth the head ache.
                  • 50j
                    • 1047
                    What he said. There are enough problems that can come up without starting out with one. If nothing else you won't have that to worry about.
                    • Ssm31
                      • Nov 2011
                      • 12
                      We use to stitch ours than patch on the sidewallsbut only used them as spares never hAd any problems.
                      • autoshop
                        • 58
                        take it to a tire shop that recaps truck tires and ask to have the race tire vulcanize on the sidewall. this process melts rubber into the hole in the sidewall and leaves a boot on the inside area the size of dollar bill. you can have them buff down the area so you can either run a tube or tubeless. the repaired area is stronger than the rest of the tire sidewall. I used to do the repairs for years before I retired from the tire business.
                        • LITE-INN
                          • 12473
                          ask dirt mod17 x he 's and expert with mod tires
                          • dirty white boy
                            • 1238
                            thats what i said week or so ago,..itll hold!! seen a many truck tire have this done an run tire with 110lbs of air with loads of 100,000lbs an excess for years,..re cappped an ran bald again...
                            • littlevoice
                              • Sep 2012
                              • 1
                              i think should only use it on the front
                              Hostgator coupons
