Roll on rr
  • CHRISTINE
    • Sep 2008
    • 341
    Roll on rr
    Whats the normal amount of roll on rr on a spring behind car?
    Im getting 4-1/4 inches on my slider mounted in front of rr is this to much?
    200 LB RR SPRING WITH 93-5 OIL SHOCK
  • racin6mod
    • 2172
    sounds like to much but wheres the panhard bar if it has a lot of rake in it that could be the reason also a 93-5 is an easy down shoch might try a straight up 95. how's the car handling lf on the ground or 3 wheelin
    • CHRISTINE
      • Sep 2008
      • 341
      Roll
      J bar is center pinion 5 inch up on frame 18 degree ru bar 1.0 rl bar it is carrying lf about 12 inches through center and off
      • hammond
        • 414
        could go to a 225 rr and put a 25lbs lead weight as far forward inside the left door and up about half way in height.The 25 lbs would be about where your feet are at .
        www.hammondmotorsports.com
        http://www.facebook.com/#!/pages/Ham...26044754164488
        • CHRISTINE
          • Sep 2008
          • 341
          Roll
          I think im gona try the 225 first what is a good amount of roll?
          • hammond
            • 414
            3-3 1/2'' but all depends on where your spring is mounted at . If the car still picks up the Lf more then 1-2'' then try that weight
            • CHRISTINE
              • Sep 2008
              • 341
              Roll
              Ok.
              My lower mounting point is 12 inches from inside of tire with 2" off on the rr and the spring lays in 15* and forward 9* is that to far away from tire?
              • hammond
                • 414
                Thats about 3" inboard more then what I run . That will work just need more spring and maybe a little stiffer shock . I would not move the coil over just work on the spring rate at this time .
                • CHRISTINE
                  • Sep 2008
                  • 341
                  Roll
                  Thanks im not on a coilover on the rr i have spring in front and shock behind all on b/c does that matter
                  • Hamilton Motorsports
                    • 38
                    If your running spring in front the shock should also be in the front.
