3 link ????
  • fugaf1
    • Jan 2010
    • 13
    3 link ????
    this is a question for the people in the know out there.. the setup i keep hearing about is to run the spring in front on the left rear and on top of the right so i think i want to go that route, but im not sure where to mount the spring? is it best on top of the 3 link mount or somewhere else, also where is the best place to mount the shock? front or back. thank you in advance, just trying to measure twice and cut once.
  • SnapOn35
    • Apr 2011
    • 28
    put the left rear on a clamp bracket infront with shock behind
    • Kojak_9x
      • 179
      Yep, what snapon35 said!
      • dirtrace09
        • Aug 2007
        • 746
        Why not run spring behind on a slider on the right rear and the shock in front? Spring on the front and shock behind on the left? Or does having the spring on top of the right rear do something better like stabilize the car?
        • charcoal01
          • 545
          Spring behind on the right rear can dewedge the chassis and make handling more erratic. Mount spring on lr 5 inches from edge of housing to center of spring, 15 degrees in, slightly tilted back.
          • Wesmohr
            • Apr 2009
            • 5
            The best 3 link i ever had was swing arm LR spring on the housing RR. Got realy slick you could put spring behind on RR.
            • dirtrace09
              • Aug 2007
              • 746
              Sorry for the all the questions. I am just trying to understand the 3 link setup. So keep the spring on top on rr unless it goes totally slick then put it on the rear. Why couldn't you run a stiffer spring behind on the rear to take away the dewedging then put a lighter one on in the slick? With both sides clamped up it would seem it would work. However, I have never ran it and trust those that have. Really just thinking outloud.
              • charcoal01
                • 545
                Because its a variable that's hard to adjust for. I've run the rr on top on some super slick tracks and had really fast cars. Keep your ballast up high and run a 175 in front on the lr and a 200 or 225 on top on the rr.
                • propit21
                  • Jan 2011
                  • 126
                  is the 3 link your working with a pullbar or soild upper link?
                  • Dirtrunner35
                    • May 2010
                    • 632
                    When you run the RR spring behind the axle it dewedges the lf and RR, making the cross higher,. So it should make a tighter car.
                    • dirtrace09
                      • Aug 2007
                      • 746
                      It would have a pull bar on it. Thank you for the clarification everyone.
                      • propit21
                        • Jan 2011
                        • 126
                        if your working with a pullbar listen to what charcoal is telling, he understand the 3 link pretty good. Not to speak to him but i believe when running a 175lbs spring on the left rear make sure its a long one at least 16 or 20 inch.
                        we run a 3 link pro stock car with a pullbar or solid depending on where we run, but LR spring in front of the axle and RR spring on top. LR shock behind and RR shock behind
                        • ben_seaton
                          • Sep 2012
                          • 19
                          So if I have both sides clamped up, I should be running the spring behind axle on LR and spring in front of axle on RR. Is this correct?
                          • charcoal01
                            • 545
                            No, spring in front on lr, in back on rr. Again, only put rr behind if you can't run it on top.
                            • fugaf1
                              • Jan 2010
                              • 13
                              would it be ok to run a coilover on the left rear or should you go with a slider and shock?
