4 link bar angles
  • jsf74
    • 544
    4 link bar angles
    Just wondering what the rr upper bar angle should be for a dry slick track. From what I can find it's supposed to be around 16 to 18 but mine is at around 10. I've been trying to loosen car on entry and in the middle. What will this low at an angle cause?
  • Flyin Iowan
    • 558
    i run mine 15-18 deg. but whatever it takes to work is what you gotta do. my experience is lowering the top right bar loosens me up, with it lower it doesnt load the rr spring. raiseing it would loosen middle up. I would use the bottom bar to make the adjusments you want(raise it)
    Chris Zogg
    • ChadJacks
      • Sep 2012
      • 39
      on an extremely dry slick track we lower our right side bars all the way down and shorten the bar length about a 1/4". shortening bar length on right side for extremely dry slick track helps a TON!
      • jsf74
        • 544
        By all the way down I assume you mean 0 deg correct.
