Spring question
  • MattMitchell
    • Mar 2012
    • 62
    Spring question
    I had a thought about lengthening my LR spring 4bar left z link right LR spring behind, my question is if I have a x amount 13 inch LR spring and I want to go to a 16 inch spring to keep the spring on the perch during hike up and while on the bars, would I increase x rate with a taller spring or go softer? Thanks
  • Flyin Iowan
    • 558
    say you have a 13" 200lb spring and at full lift it comes off the spring, you will need to go softer if you go to a 16". id say a 175 or 150.
    For example if your LR weighs 600lbs, that 13" spring is compressed 3". A 16" 200lb spring will also be compressed 3" so they both will come off the spring where as a 150 will be compressed 4" so that will help keep the car on the spring at full lift
    Chris Zogg
    • johnny v
      • Mar 2011
      • 197
      Chris is right....
      you have to drop the spring rate to keep it on the spring....length only matters if you get into coil bind... ( short springs loaded so much the coils touch)
      Go 16" and around 150 or 125.... I have tried both on a 09 shaw.....
      DON'T MESS WITH THE 20" SPRINGS....
      trust me... I spent a bunch of time messing with the 20" springs....ended up with a 16" ....
      see ya johnny v
      see ya
      johnny v
      • MattMitchell
        • Mar 2012
        • 62
        Thank you guys
