I'm wanting to try a straight bar on my car... What's a good starting point on the rake and where to mount it on the pinion...any help would be greatly appreciated
Help with straight bar
How long of bar are you going to try, you are taking about a panhard bar from lr frame to front of pinion? The longer it is, less rake needed. If its around 12in or longer, try about 3- 4.5 inches of rake, shorter try around 6in. Start center of pinion to one hole below if 9in rear end, QC about 1in above center of pinion. Good luck.
