Street stock to Mod Q's
  • Dirt Knife
    • Jun 2012
    • 147
    Ran top 10 S. Stock last year 3300lb. 1725 across nose with 700RF 750LF spring
    Bought a mod 2500lb 1025lb across nose thinking 500RF and 550 LF spring???
    It had 800RF 700LF when I bought it tryed it once didnt like it 2 Pushy
    Thoughts anyone??
    Less mass up front yet more speed into corner
    Lower ride height yet more engine set back
    DW8 chassis even their base line set up is way more than my S Stock was???
    Thanks
  • CsR41
    • Aug 2010
    • 169
    Need more info on your car to be able to help any.
    • FLYNBRYAN
      • 351
      What stub is the DW8 have?, what springs where ran in the car?
      • Dirt Knife
        • Jun 2012
        • 147
        info
        Impala stub undr slung rear 4link lr z link rr
        springs were the 700 and 800
        what other info do you need??
        mass up front is 1025 with 1500lbs of spring??
        compared to s. stock 1725 up front with 1450 lbs of spring
        turn it into a ratio the mod should have aprox. 350 and 450 for front springs
        it;s not about the push the car had I think it's to much spring in the nose of the car
        what u think??
        • charcoal01
          • 545
          I think the motion ratio of your lower a arms are different and require more spring. I'm sure someone can give you the spring recs for a dw8 but for an impala stub it sounds about right.
          • powerslide
            • 2696
            Dw8's had a Chevelle stub unless someone changed it. Lr behind floated or clamped in front?
