I'm new to mods and I have a four bar car that I'm running as a limited modified. What is the difference between having having a coil over shock/spring behind the rear end on the LR or running a shock eliminator with spring behind the LR with the shock ahead of the rear end. Which setup is preferred?
LR shock/spring
preferred on LR is shock in front of axle slider behind and coil over the RR in front of axle is your brake floated on the LR?
I ran the shock in front of the LR and the slider behind last weekend. The sling is unloading on the slider when the car rolls over. Should I go with a taller spring? And if so, do I change the spring rate to compensate for the taller spring? I currently run 200 on LR and 175 on RR.
I ran the shock in front of the LR and the slider behind last weekend. The spring is unloading on the slider when the car rolls over. Should I go with a taller spring? And if so, do I change the spring rate to compensate for the taller spring? I currently run 200 on LR and 175 on RR.
No, The spring unloading won't hurt anything. When the car is up on the bars, the spring is out of play.
