I'm lost, need help badly
  • oldtrackchamp4x
    • 270
    What weight is RF spring? How much LR drop? Did you check your RF ride height to make sure it was 3/16 lower then the LF? Check it at the center of the front Aframe bolt before adding or taking out rounds. JMO
    • washeduptoo
      • 1353
      Its all set to specs, rf is 600 spring. I didn't measure to see if its lower but will in the shop. It should be still higher than the lf. LR drop is 4 1/4.Thanks
      • charcoal01
        • 545
        If you took two rounds out of the rf and put two rounds into the left rear I think you actually took wedge out of the car. On my car if I take two out of the front I h e to put four rounds back into the left rear in order to come back to my numbers.
        • washeduptoo
          • 1353
          Your probably right since the threads are different, but at this point, I'm not really concerned about the wedge, just getting the chassis over on the rf better. Only have 1-2 races at the most left and would like to know what helps for next year. Thanks for the help.
          • xxxmod
            • Jan 2012
            • 111
            Originally posted by washeduptoo View Post
            XXXmod, I did check the pull bar ht and its 12in above center of axle tube. I guess its about ready except washing(again) and we'll give it a whirl tonight. I'll let know if its improved and again thanks to all for the help and suggestions.
            10 - 12 " above centerline should be right but IMO the pullbar angle should be 12 degrees at ride height.
            J bars with a lot of rake generally pin the right front,do not exceed 6" difference between mounting points,move the whole thing down to promote roll
            When looking at your car is the RR sticking out farther than the RF.... It shouldnt be
            • charcoal01
              • 545
              In my experience bite and/or wedge will help the car onto the rf. as weight transfers fr front the rear your lr will transfer to the rf an so on, so if you take weight away from the lr tire, you will be less likely to transfer that weight to the rf. another thing you need to think about is "helping the car get onto the rf/ right side" as speeds slow down. The slower you are going, the less weight you will transfer. Things like j bar rake and shocks will help this. What shock do you have on the rf and what sorta bite are you running?
              • oldtrackchamp4x
                • 270
                Wash Please check your PM.
                • washeduptoo
                  • 1353
                  Charcoal01
                  War shocks dry slick pkg and BSB dry slick pkg, both are low compression and slow to rebound with high gas pressure lr. Running 20-30lr bite, I guess I should have said wasn't really concerned about 5-10lbs difference.
                  xxxmod
                  The rr doesn't stick out past rf. That is what has me confused, we have enough rake(spec) to make it pin the rf but doesn't.
                  One of the reasons we didn't catch this problem earlier in the year, was we were running Keyser lowers and thought this was normal since its made different and had to run an extention on shock. Got the Keyser bent and put stock lowers on and that is when we saw the problem. I mostly work on it by myself and only race when time/money allows. Thanks for everyones help.
                  • Dirtrunner35
                    • May 2010
                    • 632
                    Maybe I missed it somewhere , how does the car handle ?????
                    • washeduptoo
                      • 1353
                      Handles good except it really loose entry and on the throttle. We've tightened car up with bars as much as we can. 225 rr spring, IRC said it should be rolling onto the front more and we think that also. 4 different drivers and they all say the same thing. We put the car together so it might be something there but we've put cars together before and no problems.Thanks
                      • Dirtrunner35
                        • May 2010
                        • 632
                        Is this a spring behind car ???? My straight bar has 8 inch difference in height I think, lowering the rear roll center will give more roll but less weight transfer to the RR. You say your car is loose going in?????????? The rear wants to come around on you???? Is 4 1/2 inches of drop enough ??
                        • washeduptoo
                          • 1353
                          Spring behind car. We tried the straight bar in practice 1st of the year and it would bury the rf but we also had brake problems then on rf. I think I might just put the straight bar back on and give it a try in a couple of weeks. Loose on entry and loose on the throttle, it trys to break loose. Just need some traction everywhere. lol
                          We started 17th the other night and passed a few cars and finished but 9th but needs to get better for me to able to keep racing. (bent lf spindle in heat) Thanks everyone.
                          • xxxmod
                            • Jan 2012
                            • 111
                            Rear end housing Straight?
                            Square up the rearend with the midplate
                            70-80lbs LR Bite
                            go 15 points taller gear
                            JMO
                            • washeduptoo
                              • 1353
                              We did go up in gear(5.88-6.02) this past weekend but it was at a track we haven't run but once before. Going to put straight bar on for next race and have a lighter spring for rf if that it that doesn't help. Thanks again to everyone for the help.
                              • Dirtrunner35
                                • May 2010
                                • 632
                                If your loose going in and get on the throttle it will stay loose on the throttle, is your RR tire burning up?? Tire pressures ? Last year I drove someones spring behind car in practice and spun out 2 or 3 times, didn't like it, way to loose for me.
