What size quick Change gear do I use for fayettr County Speedway I have a 08 shawl with the 406 Chevy small block and I want to get 8200 RP M's
gear help for quick change
if you have a 486 ring and pinion you will be close with the gear recomended if you have a 411 ring and pinion go up on that gear 40 to 50 points 680 or so.
differences between 4.11 and 4.86
I have been experiencing that as well, needing a little more gear with my new 4.11 winters QC. It has been about 40-50 points more than what guys are running with their 4.86 QCOriginally posted by not clamped up View Postif you have a 486 ring and pinion you will be close with the gear recomended if you have a 411 ring and pinion go up on that gear 40 to 50 points 680 or so.
What is this all about? any ideas?
Call franklin we wasted a couple of nights not knowing there is a difference,and I can't remember all of what they told us but we started using the right gears the problem goes away,and u also have to watch who you ask about gears there is alot more 411 gears than in the past.Originally posted by dukesracin View PostI have been experiencing that as well, needing a little more gear with my new 4.11 winters QC. It has been about 40-50 points more than what guys are running with their 4.86 QC
