Rem finished gears
  • TDR
    • Jan 2010
    • 85
    Rem finished gears
    Looking for good and bad stories for rem finished r&p gears in a quickchange... Getting ready to order a new rear end and want to know if its worth the extra money
    Thanks
  • racin6mod
    • 2172
    the only bad thing I've ever seen with the rem finish is water quickly stains it and rust builds up fast if it's not lubed with oil as soon as possible.
    the pros gears run cooler and in the case you loose a seal or bearing as we did the rem finish saved the gears it only takes a lap or two with oil out enough oil to ruin a gear set.I get used 9 inch gears from r/y racing and rcr and both teams use rem the gears are as good or better than new.they even do all the gears in the trany as well as the crankshafts.
