Very last night we raced I had trouble getting the transmission into high gear. It has only been 4 nights since complete overhaul of all internals. Now on jack stands I can't seem to get it to lock in high. Any suggestions?
Bert trans wont go into high gear
are you running the car on jack stands or just trying to pull it into High without anything turning / running?
I would just pull it out and play with it on the bench..... shifting into high is just Mechanical stuff..... test the shift rods, pull the side cover and see what is happening........maybe the shifter is the problem...Last edited by johnny v; 12-21-2012, 10:11 AM." Most of my drivers have been new to 4 link stuff and I believe most of their chassis issues are really my driver issues....... "
see ya
johnny v
i agree with johnny v -and while you have side cover off make sure roll pin is not broke that pins shift fork to shift shaft i have had that happen and it won't go into high something to look atOriginally posted by johnny v View Postare you running the car on jack stands or just trying to pull it into High without anything turning / running?
make sure the rev lever is in nutral if it's not that will cause the same issue your having. if one the linkage rods got bent just a little you may need to readjust your linkages. if that doesn't fix the issue than the pin that locates the fork on the shifting shaft has broken or it has can out.the rebuilder should have replaced both of them.
