has anyone welded this in at a angle so when you slide the mount up or down you wouldn't need to resquare the rearend
panhard bar frame mount
The only way that it works is if you are running the exact length and angle panhard bar that the bracket was designed for. If you raise the bar at the pinion you have to raise the radiused brkt on the frame the same amount.If you lengthen or shorten your panhard bar, then the radius is wrong.You still have to adjust the panhard in most circumstances.IMO it is a waste of money that could be spent on making the car go faster. Something like tires.
