When do you use a short straight bar?
  • cgs
    • Jan 2009
    • 91
    When would you use a short panhard mounted under or on the driver side of the pinion? Tride to find some posts about it but my Internet is too slow thanks
  • racin6mod
    • 2172
    the short one on the drivers side of the pinion I would say only after all else has failed. the longer one under the pinion worked great for me on a short tight turned track. the bar was 18'' long and had 4 1/2 inches of rack in it.
    • cgs
      • Jan 2009
      • 91
      Were you using it on a hooked up track? Or when it dries out?
      • JustAddDirt
        • 1893
        straight bar
        Typically a smooth, slick track.
        • racin6mod
          • 2172
          I ran it all the time once it was set never felt the need to change it. I put the quick change back in so I'm going to start with a j-bar and move from ther. the lower pinion may be to low but we'll see.
          • johnny v
            • Mar 2011
            • 197
            I'm a big fan of the Mark Bush articles in dirt mod.... I went back and looked at one that talks about the Left / Left short setup you talked about...... He says try it when you want to loosen entry and tighten exit......
            If it gets a little too loose on entry, the try the conventional ways to tighten the car up on entry a little....stiffer Lf spring, lower Right bottom link or soften compression of the RR shock....
            IMHO
            I have worked with 2 "new to 4 link" drivers ... both had problems rolling the cars into the corners correctly and getting them to rotate.... Most 4 link USMTS type mods are too tight for a new 4 link driver to drive correctly and rotate... most drivers at the local level don't have the skill and the "knack" of trail braking or the ability to make a car rotate with the way they enter/ drive the corners.....
            So maybe the Left / Left shorty panhard bar might help the learning curve.... Once a driver "gets it"... then you go back to the J bar......
            Just a theory... but going to try it out....
            see ya
            johnny v
            • dirty white boy
              • 1238
              interesting thoughts,..like to hear how it gose when you try it,..i got a older late model chassis that was built to run straight left/left short bar,..but with a rubber block between frame an bar,...lest thats what was explained when i searched back threw the previous owners,...said it was did away with an used a normal j-bar,...tryed getting up with barry wright few times on phone to confirm this but yet to get any info,..dont keep records that old an barry travels alot...lol
              white trash motorsports
