transmission question
  • porkchop4
    • Sep 2012
    • 87
    Last year our rules said we had to run.an oem transmission now this year we can run a bert brinn falcon or racegator....I've never heard of s racegator are they as good as a bert or brinn and is it worth the money to upgrade from a direct drive power glide thanks
  • Dirt Knife
    • Jun 2012
    • 147
    dump the glide
    Go Falcon.
    • LM14
      • 490
      Skip everything else and go straight to a Brinn. The Racegator is a cheap imitation from the ones I have looked at.
      SPark
      • powerslide
        • 2696
        SPark
        i agree w/ the brinn over bert and falcon. No experience w/ a racegator and havent heard much on them.
        • MM90
          • Oct 2010
          • 422
          Brinn gets my vote. I know of some people running the Racegator but don't know how good they are compared to a Brinn, Bert, Falcon.
          • porkchop4
            • Sep 2012
            • 87
            So it is definitely an advantage running an after market transmission...is it enough to justify the cost and why do most of u choose brinn over the others
            • dirttrackrocker
              • Nov 2010
              • 664
              The advantage is losing the rotating weight of the clutch. Brinn is by far the best of the bunch, it shifts much easier and lasts longer between rebuilds. I bought mine used for $700 with a fresh rebuild. Also the Brinn is the same length as a Saginaw so you won't have to get a longer drive shaft like you will with a Bert.
              • porkchop4
                • Sep 2012
                • 87
                Now if u were to go out and buy a brinn would u need besides a bell housing
                • racin6mod
                  • 2172
                  SPark
                  agree 100 percent and the racegator hasn't been around long enough to now if it's going to last more than a couple of seasons.
                  you'll need a coupler and a 153 toothflex plate.
                  • porkchop4
                    • Sep 2012
                    • 87
                    Do u need a special clutch or something i know nothing about after market transmissions
                    • Confused?
                      • Apr 2009
                      • 418
                      I favor the Brinn over the Falcon. The Falcon uses an intermediate shaft between the coupler and the transmission. The Brinn does not.
                      The clutch is internal. No need for another. You will, however, need a master cylinder and clutch pedal to operate it.
                      • porkchop4
                        • Sep 2012
                        • 87
                        So i need a hydraulic clutch and what kind of coupler do i need like what should i look up
                        • Confused?
                          • Apr 2009
                          • 418
                          Brinn makes a coupler for thier trannies. Don't use the aluminum one. Get a steel one. They last forever. Use the flexplate you already have. You will need longer, grade 8 bolts for the coupler.
                          • LM14
                            • 490
                            i have aluminum couplers that are several years old. The steel ones tend to beat up the splines a bit.
                            To hook one up is really simple. You bolt the drive hub to the crank hub with a standard automatic tranny flex plate sandwiched between the hub and crank. You bolt on your bellhousing then the tranny input shaft slides into the splines on the coupler. You hook your clutch pedal 3/4" master cylinder to the built in hydraulic system in the Brinn. Braided flex line works fine. You use a 2 lever shifter. One lever is reverse, the other is lo/hi. Bleed it like a brake caliper and you're ready to go.
                            Drop it in lo, start to rev the engine a bit and push the pedal in to make the car move. Once it gets up to speed to roll on it's own, you get off the gas and pull it back into hi. You are now direct drive. With a Brinn, that means nothing else is rotating weight other than the main shaft thru the tranny. Brinn is the easiest to shift of the bunch. Takes some getting use to.
                            SPark
                            • jsf74
                              • 544
                              Love my Bert.
