What type pull bar works best on a super slick track?
  • ohiovalley05
    • Aug 2012
    • 31
    Running a 4 bar car with biscuit pull bar when track slicks over a lot we cant get traction. Is the spring bar better in the slick for forward bite?
    How about the adjustable hydraulic pull bars are they worht the money if they are legal?
  • hammond motorsports
    • 269
    both the spring and bars work well you just need to adjust the rate of them for the track. With the biscuit pull bar you will need to replace the biskets often. What biscuit bar are you running? Small or large?
    http://www.facebook.com/pages/Hammon...26044754164488
    • HEAVY DUTY
      • 796
      They both are good or bad. A pullbar is a very small part of what makes traction. If the pullbar is right and a few other things ( springs, shocks, weight percentages, engine torque curve, carb linkage, drivers foot, stagger, etc.) arent right, the pullbar wont make a difference. People put too much emphasis on pullbars and overlook a lot of ather more important stuff. A pullbar that is too soft is no good. A pullbar that is stiff enough will get you 80 % of what you need. A bushing pullbar is more progressive than a spring bar, and therefore doesnt allow as much travel. Angle, length and left to right placement are all fine tuning adjustments, but wont hook up a car that isnt somewhat hooked up already. Biscuit type pullbars need the bushings replaced on a regular basis, they do go bad and lose traction. A spring that has coil bound on a pullbar also goes bad. A solid bar with no spring or rubber will give you enough traction to win if everything else is right. My advice is to make sure what you have is right, and spend your money on tires, rather than buying the latest greatest marketed part.. If a guy bought everything he could that was supposed to give him 2 tenths here, and 3 tenths there, he would be running laps faster than zero seconds.
      • johnny v
        • Mar 2011
        • 197
        The deceleration part of the equation seems to be where all the R+D is happening as far as pull bars / lift bars go.....
        see ya
        johnny v
        • HEAVY DUTY
          • 796
          That is one reason I like the biscuit type bar. They dont have as much travel and dont rebound as hard into the brake biscuit. The harder they hit the brake biscuit on decell, the more they upset the car on entry.
          • johnny v
            • Mar 2011
            • 197
            yes sir, and there is the loss of MOMENTUM...
            see ya
            johnny v
            • oldtrackchamp4x
              • 270
              Agree with Heavy Duty. I've run both and could'nt tell any real difference. Also, for me, on dry slick throttle control is the biggest part of hooking up a car, IF everything else is set up correctly .JMO
              • Flyin Iowan
                • 558
                Is everyone getting away from the red rubbers on the rebound side?? How soft do you use?
                Chris Zogg
                • HEAVY DUTY
                  • 796
                  I just use the regular rubber ford strut rod bushing on the brake side. I think tuning the brake side with different bushings might be hard to feel. They are only gonna move 3/8 to a 1/2 inch no matter what bushing you have.I think that there are a whole lot more effective ways to tune entry. I think guys are doing that to sell pullbars. I might be proven wrong but I like working where the gains or losses are more noticeable. When you are working with little things, it is hard to tell if the change made it better or worse or if the track changed.
                  • Dirtracer50
                    • 140
                    Don't mean to hijack the thread but have a question that kinda fits the topic. Does the 90/10 or whatever valving one chooses shock have any different effects when moved side to side on the chassis and rearend? I've never ran a shock above the pull bar but last race of the season the pull bar mount broke out of the chassis causing a ton of damage. I'm thinking the top shock would have helped prevent this so I'm putting one on just not sure where to mount it side to side. Thanks for any help.
                    • racin6mod
                      • 2172
                      I would center it the best you can. it does make some differance but nothing like moving the pullbar left or right.
                      • TeamLFR
                        • Sep 2012
                        • 6
                        adjust
                        If car is working on tacky track couldnt you just put in a round of bite into the car? Sometimes 2 sometimes three? Assuming one round in the car is approximately è0lbs.
                        • ohiovalley05
                          • Aug 2012
                          • 31
                          Adding a round of bite how?
                          Thanks for all the input
                          • washeduptoo
                            • 1353
                            I think he is talking about putting some rounds in the lr to add bite.
                            • ohiovalley05
                              • Aug 2012
                              • 31
                              I see, thanks.
