Leaf Spring Baseline Set- up???
  • J-ROD81 81
    • Jun 2012
    • 8
    I have an 03 Predator leaf spring chassis, does anyone have a baseline set- up i could use or any ideas on what i could try, its my first time racing and just looking for something to start with. any informtion would be a big help.
  • Reddy Powered
    • 176
    Are you running a Fastboys type left side leaf? Or is it just a regular leaf spring?
    • J-ROD81 81
      • Jun 2012
      • 8
      The guy told me to look up the fastboys leaf and it would tell me everything but of I read it right it was talking about rebuilding the leafs and it confused me a bit but it is a fastboys setup I believe
      • Dirtrunner35
        • May 2010
        • 632
        So you have leafs already on the car ?
        • Reddy Powered
          • 176
          If the left side leaf looks beefier in the front then it is a Fastboys type leaf. I say type because to be an exact Fastboys leaf it would also have a huge arc as well and would most likely be in the top mounting hole in front with a really tall lowering block on that side and longer shackles as well. There would also be a birdcage on the right side to allow the axle housing to rotate freely on that side.
          With a Fastboys type leaf on the left, the setup depends on whether or not there's a birdcage on the right as there would be a big difference in what you want to see when scaling.
          • J-ROD81 81
            • Jun 2012
            • 8
            there is leafs on the car and its is beefier on the left in the front
