9" to QC
  • Reddy Powered
    • 176
    9" to QC
    I'm switching from a 9 inch to a quick change. I've heard that your gear ratio will change when doing this. Just wanted to see if anyone has any experience with this. I just want to know what gear to buy first for my home track. I've been running a 5.67 with my 9 inch and was thinking of trying to get close to that. Maybe 5.70 or so?
  • HEAVY DUTY
    • 796
    No reason to change gear. Get as close as you can to what you were running.Hook the panhard bar an inch and a half higher in relation to the pinion than where your 9" was
    • js11
      • Apr 2011
      • 91
      All things being equal or unchanged from before the QC (i.e., same chassis, motor, etc), my experience was that you could run anything from a 5:83 to a 5:88 if the gear you ran before the change was a 5:67. However, as Donnie mentioned, you could very well still be in the ballpark with a gear close to a 5:67.
      • xxxmod
        • Jan 2012
        • 111
        Be happy happy ,now you can run a 5.83 in the heat and 5.60 in the
        feature with out breaking a sweat changing gears.
