Lower ball joint help
  • crateracer16
    • Apr 2009
    • 332
    I'm trying to find out what lower this may be and what balljoint I need. It's a press in style. I have tried qa1 pn 109 and it was a touch too big and a ball joint for a 81 Monte Carlo is way to big. I use 5" springs with no problem. Is it a nova?
  • mudeater18
    • 1599
    That might be a Lightning Nova style lower. The ball joint they use will not press in, but fit loosely and have 3 tack welds on the bottom to hold it in. Call Donnie or Vickie at 606-878-RACE or lchassis@aol.com or HEAVY DUTY on 4m and they'll tell you what it is.
    • crateracer16
      • Apr 2009
      • 332
      The ball joints that were in it were exactly how you described. Thank you
      • JustAddDirt
        • 1893
        lower
        It looks like a pierce lower, but someone might have changed the balljoint. Lightning (that I am aware of) never used a heim on the chassis mount. Used a plastic bushing and sleave.
        • crateracer16
          • Apr 2009
          • 332
          I emailed lightning and they believe its a pierce or allstar lower. Going to try the 73-81 truck ball joint they recommended. Thanks.
          • bittight
            • Jun 2009
            • 358
            Pretty positive it's pierce, might call n get the insert that adapts it to a screw in and have more variety in screw in ball joints
            • crateracer16
              • Apr 2009
              • 332
              Call pierce to get the inset or does someone else carry it? Thanks
              • bittight
                • Jun 2009
                • 358
                Pierce, b sure to tack them in as well
