Lubing axles
  • TDR
    • Jan 2010
    • 85
    Lubing axles
    Does anyone lubricate the axle before installation... Wondering more on the spool side
  • racinjj
    • 98
    Just put a little grease on each end and you will be fine.
    www.UltimateRaceCars.com
    • lazermod3
      • Jan 2008
      • 1910
      NO! use never-seize
      you just got greased
      http://www.goddardwarrior.net
      • Flyin Iowan
        • 558
        I use grease as well, never used to do anything but a top late model team said to use grease
        Chris Zogg
        • MM90
          • Oct 2010
          • 422
          Are you lubing axles with steel or aluminum spools? Or both?
          • TDR
            • Jan 2010
            • 85
            Aluminum.........
            • racinjj
              • 98
              I always lube the axles regardless of material type, its just good practice to make sure everythign moves as freely and possibly. Plus the grea wont damage anything if it mixes in with the gear lube.
