Hey guys, just have a general question and looking to gain more knowledge on the subject. Why are current 4 bar spring behind cars with a chevelle clip running lighter springs on the right front than the left front? I have tried on a couple different occasions and cant get it to work at all. I am just confused cause it seems like every other car has this except mine. Any ideas?
Spring technology
What spring rates you running up front? If you go soft RF make sure you do it based on travel. If you are not bottomed out or near bottomed out they dont work. You can send me a PM if you want some direction in specifics. What brand of chassis are you running.
left side wieghtOriginally posted by Hagen14t View PostHey guys, just have a general question and looking to gain more knowledge on the subject. Why are current 4 bar spring behind cars with a chevelle clip running lighter springs on the right front than the left front? I have tried on a couple different occasions and cant get it to work at all. I am just confused cause it seems like every other car has this except mine. Any ideas?
j bar rake
engine location
aluminum heads
All of these make a big difference in how much right front spring you need
I have a chevelle front and drag the frame some with a 650 RF...and yea the car is fast
springs
Also shock packages will have an big effect on springrate.Originally posted by Hagen14t View PostI have a 650 in the LF and a 750 in the RF. The RF shock is about 1 inch from bottoming out. I just don't get how some of these guys are running 450s and 500s up there and I have to run way stiffer.I think there should be lifeguards in the genepool.
To many variables, with most listed by those that have already responded. Just thought i'd add one more. Driving style. But that is JMO.
ditto on the above....Originally posted by oldtrackchamp4x View PostTo many variables, with most listed by those that have already responded. Just thought i'd add one more. Driving style. But that is JMO." Most of my drivers have been new to 4 link stuff and I believe most of their chassis issues are really my driver issues....... "
see ya
johnny v
Front roll center is prolly the biggest variable...what are other ppl with you chassis running that's prolly close to where u need to be...roll centers too easily manipulated and has too big effect...some guys can run 300 RF some can't below 550 or so
engine location is the biggest factor, both laterally and vertically. a car with the engine at center of cross member will almost always need more RF spring than a car with engine max allowable distance to the left.
What problem are you having running a softer RF?Originally posted by Hagen14t View PostI have a 650 in the LF and a 750 in the RF. The RF shock is about 1 inch from bottoming out. I just don't get how some of these guys are running 450s and 500s up there and I have to run way stiffer.
Those Chevelle clips have a real low motion ratio. You could easily soften RF another 50 lbs with no problem, maybe more. Just keep an eye on tie rod hitting the frame.
One inch is a long way from bottoming out with todays setups.
