bert trans question
  • OWM50
    • Mar 2009
    • 42
    bert trans question
    been a while since I had to take the drive flange off the motor and I cant find my manual or remember if the flange had to be torqued to the motor... can someone help me out?
  • cavemod
    • Jan 2010
    • 135
    yes it does the same torque figure as the flywheel or flexplate bolts dont forget to put some locktite on the threads
    60-70 ftlbs.these numbers come from a haynes manual
    • zachmckenzieracing
      • Dec 2010
      • 36
      torque
      i recommend that you tighten them to 65ft lbs. also you a little thread locker on the end of your bolts of security. dont go over board with the loctite. just a lil dab does it. using too much makes it a pain when replacing it. if too much is used, and the holes arent cleaned out, this may cause the bolts to not tighten correctly and vibrate loose.
