I have new D's and New A's, how should I go about on a break in/heat cycle on these tires before sent out for the A-main?
How to break in UMP mod tires
They'll last longer,not chunk out on rr and feather less if you run a heat race or 2 on them and wash them with simple green before you set them out for a high heat cycle in the A, unless u buy em at the track we never put on a green tire then run a feature.
Simple green will make you fail tire tests from what i hear.Originally posted by bittight View PostThey'll last longer,not chunk out on rr and feather less if you run a heat race or 2 on them and wash them with simple green before you set them out for a high heat cycle in the A, unless u buy em at the track we never put on a green tire then run a feature.
