rr spring question
  • junebug
    • 363
    rr spring question
    My car was a little tight on entry when the track had grip in it...which would be a better way to loosen entry...softening rr spring raising jbar or raising rr lower bar up
  • Flyin Iowan
    • 558
    Im guessing you mean in a heat race? so i would do the easiest change just to make it eaasier to change back for feature. If you need that spring for when the track loses grip then i would raise lower bar. if you have the climber brackets for the jbar then that might be the way to go.
    Chris Zogg
    • junebug
      • 363
      Yep its a little heavy in the heats and bone dry in feature...i like the heavier spring for side bite in the dry...also I do have the climbers on both sides of jbar...i have seen guys with there rr lower bar at 7-8• mine is 1-2• ...my jbar is 1/2" above pinion and 5" of rake..should I just raise the whole jbar up an inch? Or maybe leave it and raise rr lower?
      • powerslide
        • 2696
        i would try the RRL bar adjustment first see if you like that.
        • Flyin Iowan
          • 558
          i thought about it more after i posted....if the body roll isnt to much then i would do the lower right bar. i would do the jbar if the car is on the RR to hard and rolling over to much
          Chris Zogg
          • junebug
            • 363
            how much angle do u guys run in it....5-8• or so sound ok?
            • Flyin Iowan
              • 558
              honestly whatever works. You know what you need for the feature so for the heat race move it up 1 hole. If thats not enough try 2 holes the next time. Ive ran mine anywhere from 1 hole below 0 and 2 holes above.
              Chris Zogg
              • powerslide
                • 2696
                that sounds close for a hooked up track.
                Sent you a PM of something different that might help as well.
