Chevelle stubbed modified, having problems turning left and right. With motor running and stationary, it takes two hands from outside the car to turn the wheel left and right. I've raced it like this twice and after 20 laps I am DONE! This is what I've tried:
Different Power Steering Pump (known to be in good working condition)
New Steering Box from Oreillys (not the cheapest, but it is under lifetime warranty so it is free)
Better Fluid - Royal Purple
I took the quickner off to see if that was my problem, no luck. With quickner removed and car on jack stands, I can move the left front wheel back and forth. When moving the wheels, turning right always has resistence. When I turn back left, there is no resistence for about 1.5 turns of the input shaft, then the steering gets hard again. I turn lock to lock with the cap off the remote reservoir, the fluid begins to rise higher and higher until a certain point, then stop and remain at that level as I continue to turn the wheels. Is this a sign that there is air trapped, or is this normal?
I can start the car and turn it lock to lock with and without the cap on the reservoir and the car on jackstands. It isn't as easy as it should be to turn off the ground with the motor running.
What would you try next? Could it be the new box?
