e85 vs gas
  • modman67
    • Aug 2007
    • 167
    e85 vs gas
    For you guys on e85 what is the difference in consumption for a weekly show. I'm on gas now and a 10 lap heat and 20 lap feature I burn about 10 gallons. What would the consumption be on e85. Also do you have to change jets as often as you do with alcohol?
  • BW51
    • 23
    Is there any hp gains running e85
    for me I am in the limited modified class.
    2bbl 10.0 -1 355 engine class
    If so what changes do I need to do to run it. Been hearing alot about this lately and wanted to know more about it.
    • monte1race
      • 473
      i was told by a reliable source that theres no real hp gains but the torque gain on his motor was 15 over gas
      • 9WRACER
        • Feb 2009
        • 585
        response is better and pulls all the way down the chutes on e-85
        • clm15
          • Sep 2008
          • 390
          Is anyone running 13.1 comp with E-85? We run in in a Crate and its been great. Its spose to have a 105 octane? Should be good for Hi comp engines!Anyone know for sure.
          BUSTING OURS TO KICK YOURS
          • 50j
            • 1047
            Works great with the right equipment, and you'll want to check your fuel if you're not mixing your own.
            • 50j
              • 1047
              From the gas station, 84-87% tested with the test kit.
