4-link imca mod. Ford 9" rear. Falcon tranny. Just changed from a 3-link to a 4 over the winter. took it out for practice on tuesday and broke a brand new u-joint. Have a few different suggestions so far but wanted to hear what else people have to say. I have a 31" driveshaft and 5" yoke. Does this sound right or is the yoke too short? When it was a 3 link i ran the same driveshaft with a 4" yoke and had no problems. any opinions welcome.
Driveshaft question
There are variables that play into the length, such as distance of the rearend from the back of transmission, and the yoke on the rearend. Is it a long or short yoke. The common lengths are 29" to 30" with an 8" yoke. I like haveing about 2" of exposed yoke sticking out of the tailshaft at a minium.
Also check your pinion angle. Too much can break u-joints as well.
There is a lot more movement with a 4-link than on a 3-link.Bill W. and Dr. Bob......who could have known.
My car has a 29.5" driveshaft with and 8" yoke, Brinn trans. The u-joint on the rear end side is also the wide style which I think helps with the higher driveline angles. Now if I put my car on jack stands and let the rear end hang on the chains my driveshaft bottoms out into the tranny. Haven't raced at all this year, tomorrow should be the first night out. Now I know why the guy before me had a block of wood between the LR underail and the rearend when he had it on jack stands. My driveshaft is supposed to be the same as what the guy before me was running so I hope I don't have any issues.
I'm running about 6.5 degrees of pinion angle, my chassis recommends 7-7.5 to start. This is static and just putting a degree wheel on the rearend.
from what i've been told localy and the reading that i've done in general, if your rear end is at the max 72" back and you have a bert tranny you want a 8" yoke with 31.5" driveshaft. If you have a bert or falcon tranny you want a 8" yoke and 29.5" driveshaft and you will have no problems with it pulling out or bottoming out.
Originally posted by MM90 View PostMy car has a 29.5" driveshaft with and 8" yoke, Brinn trans. The u-joint on the rear end side is also the wide style which I think helps with the higher driveline angles. Now if I put my car on jack stands and let the rear end hang on the chains my driveshaft bottoms out into the tranny. Haven't raced at all this year, tomorrow should be the first night out. Now I know why the guy before me had a block of wood between the LR underail and the rearend when he had it on jack stands. My driveshaft is supposed to be the same as what the guy before me was running so I hope I don't have any issues.
You need a limiter chain on the rear to not let it bottom out. You also don't want your LR upper bar to go past 45*
We had an issue with a falcon, where the shaft was not splined far enough, and the yoke would bottom out on the shaft inside the transmission.
I think the newer ones are turned down ahead of the splines. I have an older Brinn and had the same problem. I took the tail shaft out and took it to a machine shop and had it turned downOriginally posted by JCSullivan00 View PostWe had an issue with a falcon, where the shaft was not splined far enough, and the yoke would bottom out on the shaft inside the transmission.
Thanks, but I already know this and have them on both sides of the car already. It's an over/under slung rear clip. My only problem is when I have the car on jack stands. I checked it last night and with it on the ground I have about 2" of shaft sticking out of the trans.Originally posted by dirttrackrocker View PostYou need a limiter chain on the rear to not let it bottom out. You also don't want your LR upper bar to go past 45*
you want atleast 2inches in the trans. so about 4inches out is ok.Originally posted by MattMitchell View PostSo with the falcon tranny, and a 8 inch yoke, (6 inch snout) how much should be in the trans?
MM90 if you set the pinion angle closer to what the chassis builder says it will pull it a little further out(not much but a little lol). Put a jack under the car infront of the driver and jack it up until chain is tight. Does it bottom? What type of pullbar do you have? Take pullbar travel into consideration.
See how far this thing moves?
Worth double checking what torque link spring you are using. I broke u-joints last year (several before figuring it out) that I was getting more wrap in the housing than before. u-joints would bind in the gear yoke and break. Might unhook the torque link and verify how much travel happens before it binds.
Just a suggestion.
Never thought of the torque link issue. I only have a 600lb spring in there now. Regardless, I picked up an 8" yoke, put it in the tranny 2" and then measured from hole center on yoke to hole center on rear end and came up with 29" each time. Going to have my driveshaft shortened.Last edited by ask0329; 04-29-2013, 09:35 AM.
Update: Ran the car for the first time Friday night. Ran the driveshaft into the back of the tranny, luckily it was only enough to take out the tailshaft seal. Talked to the previous owner and turns out he ran a 28.5" driveshaft. Taking ours in this week to have 1" taken out of it.
