I have the 2009 setup book and it calls for a 24" pull bar w/ blue & black bisquit(s). Is this just a regular bisquit type bar with no spring like a AFCO or other brand pull bar?
Pull bar on a Shaw
I am pretty sure this is the one Shaw was using in 09
Thanks, our older DW8 has a spring type bar on it and works good. I can find no reference to spring type, etc for the Shaw.
yeah, that is it... I helped on an 09 shaw that had been back to Shaw for updates and that is the pull bar that was on our Shaw.....Originally posted by dirttrackrocker View PostI am pretty sure this is the one Shaw was using in 09
http://img.photobucket.com/albums/v3...ps051385e1.jpg" Most of my drivers have been new to 4 link stuff and I believe most of their chassis issues are really my driver issues....... "
see ya
johnny v
We switched our Shaw over to the xfactor bushings this season and its made alot of difference in the initial bite. Bushings have lasted around 6 -8 nights before we noticed a loss in traction, but its better than what we ran last year and has lasted longer.
Every post you have made has been about xfactor, wether it be the bump stops or pullbars. I dont believe you are a happy customer i believe you are the xfactor producer. Buyer bewareOriginally posted by Dirtech View PostWe switched our Shaw over to the xfactor bushings this season and its made alot of difference in the initial bite. Bushings have lasted around 6 -8 nights before we noticed a loss in traction, but its better than what we ran last year and has lasted longer.
X factor
I use to run there stuff till couple years ago the bushing were pulling the large washer through them and it was a know problem but they wouldnt do anything about it. However if that problem was fixed and i beleave it is i would run one in a heart beat great forward bite with it.
Really? Come on man I was simply trying to help out, which they helped us tremendously this season. Christine, we used them a few years ago too and they are back to the original material which is so much better.Originally posted by save the racers View PostEvery post you have made has been about xfactor, wether it be the bump stops or pullbars. I dont believe you are a happy customer i believe you are the xfactor producer. Buyer beware
Xfactor
I dont think it was the material as much as the way they were built. The old 5 inch ones had hard rubber on the ends and the soft to get the progression in the middle then the newer 7 inch ones were 4-5 hard ribs then soft ones on on end and that is were we where having our problems. I liked it on dry better than a spring and i never liked the afco bar with bushings inside the spring it was to touchy for my heavy foot.
Never seen that one I guess, the 5 inch we run is just soft on one end. We use both the 1" and the 5" depending on the track. We tried the 7" but it was for momentum tracks but we switched back to the 5" and went a little softer. Do you have a shaw too?
