So I put new rotors,calipers,and brake pads on my car. When I bleed the brakes the pads are tight after words and wheel will not spin freely. This is on all 4 not just one. So stupid question maybe but what can I do to free this up or some advice on bleeding them properly. Thanks in advance
Brake issues need help
make sure the bias bar is free and the rods are not miss- adjusted...Originally posted by bluemod View Postthere scrubing. Seems like it has a little bit of pressure on them. When u hit the brakes they still touch the rotor
If the bias bar is ok... then what you feel with your hand is normal.... disc brakes have no mechanical return so the rotor turning under power will bump the pads/pistons back ever so slightly to make it all work correctly...." Most of my drivers have been new to 4 link stuff and I believe most of their chassis issues are really my driver issues....... "
see ya
johnny v
the car is fine. The new pads are thicker than that was on it. Didn't know if I was doing something wrong because ive never really had this issue. They use to spin very freely and now the pads are touching is there anything I can do or will it after a race stop this.
Could be that the rubber O-rings are still in the thru bolt holes on the calipers. This will cause the calipers to hang a little. There are two big ones and two little ones in each caliper where the mounting bolts go through...I have forgot to take them out before...
I guess your mounts are welded on. If they are bolt-on, you could just move the brake mount out a little. PITA to cut off a welded one and re-position.
