What can I do to loosen my entry and tighten my exit? If that's possible.
To tight on entry
It might be if you loosen your entry, exit might take care of itself. What have you tried and type of suspension do you have? You can increase lf spring rate but there are several things to try, like moving rr out, etc. Good luck.
Is this an overrail chassis? How much lr drop do you have? I guess you have tried lowering the lrb bar on chassis to help with drive off? Are you running a dampner shock on rear end?Last edited by washeduptoo; 05-05-2013, 10:50 PM.
If it was me i would just put in 2 rounds in LR, which loosens entry and gives more drive off. Works if the rest of the car is right. Also only try one thing at a time, but i would try this first. JMO
