2 link with a swingarm
  • ohlde21
    • May 2013
    • 11
    Whats ur guys thoughts on running a short swingarm on the LR with a coil slider on the swingarm and shock mounted behind axle? Whats the pros and cons?
  • RW57
    • 662
    You will love it 12in swing arm on left 20 in straight lower
    On right spring on top of housing will steer just like a 4 link
    • chapa9
      • Jan 2010
      • 60
      I've won back to back features with that set up this year on slick tracks.
      • ohlde21
        • May 2013
        • 11
        Whats a good rating on the lr spring for this setup ive been told 250,275,&325 by different peeps and also to set the car up 60 lbs heavy on the rr does this sound close ?
        • RW57
          • 662
          Depending on car weight is how you determine lr spring as a general rule of thumb spring on swing arm cuts rate nearly in half because of motion ratio there is a formula on the dirt forums tool box if you can get it to work. One thing about this set up forget everything about your old way of doing things as it will be ass backwards from everything you do now. And yes you will need little to no bite and possible dewedge we run 50 to100 pounds rr w/o driver the more rr we put in the car gets better I would start with 50 pounds w/o driver and then put him in it and see where you are. If it works like our car it will have so much forward bite you will be looking for ways to unhook the car.
