thoughts on chaining the rr...seemed to put a lot more steer in the car and that's after putting half inch of lead in rr...have it set at about an inch from ride height to hike, any other adjustments to look at to make this helpful with forward bite or should i throw it back in the trailer...thx
chaining down rr
nobody experimented w/ this? i was just curious as it seemed to add a lot more steer and made the car real loose on entry...thx for any inputpowerslave
Most people I know that run it just set it and forget it for the most part. I usually set it so that the chain goes tight just before the spring loses preload, which usually seems to be between 3/4 and 1 inch. To tight and it will get darty and steer you towards the wall on exit. Can't say I can tell you what it does out past an inch as I've never ran a mod without it and its always been an inch or less.
