have to run a long panhard behind the rearend. what would the result be of moving it up equally on the frame and the rearend do?
moving panhard
Will loosen the car. See info below....
-- If your panhard bar is mounted too high you can expect:
Loose corner handling (usually)
Little chassis roll
The chassis to be unforgiving and overly sensitive to the driver.
-- A low panhard bar works best on slick race tracks and lighter race cars.
-- If your panhard bar is mounted too low you can expect:
Tight corner handling (usually)
Excessive chassis roll
The chassis to be sluggish and unresponsive to the driver.
