I got a oil pressure issue on a fresh rebuild motor hold 60-70Psi cold and holds good until 220 degrees then oil pressure drops to 20-40 and bou. es back and forth like the motor starts cavatating and as soon as the motor drops back down to 200 the oil pressure goes right back up to 60psi what would cause this i change the oil and filter incase the filter pluged but the results were the same any ideas?
motor help
do you have oil restrictors in the rear oil galley?
what type of oil pan?
What type of oil pump?I think there should be lifeguards in the genepool.
Are you running a roller camshaft and lifters, or is it a solid lift?
Just checking, cause you may not want to run restrictors with a solid lift, or hydraulic camshaft.
What happens if you add another quart of oil?
What oil are you running?I think there should be lifeguards in the genepool.
is this on the track when it happens or just in the shop ?Originally posted by JustAddDirt View PostAre you running a roller camshaft and lifters, or is it a solid lift?
ok thanks. I know on track I have had engine oil psi drop or bounce during the race due to oil being sloshed around and then as soon as the oil gets a chance to settle back in the the pan the psi went right back up.Originally posted by ohlde21 View PostSolid lift cam ..... this happened on the track
another question please if you are at 220 and under caution does the oil psi drop or bounce ?
What brand is the pan, and pickup? I have heard of this with cheap pans, and not many trap doors, and baffeling to control oil slosh.
Does the pan have trap doors around the pickup. if so how many?
How big of an area is the pickup in? If the pickup is a small one, and the area it is in the pan is pretty large, without trap doors or baffles, just wandering if the oil is moving around the pan a lot (as stated above), and sucking a bit of air.
I would try another quart or two and see if it fixes problem.
Of course oil will get hot, and thin out. What weight oil u running.
Remember the oil saying on oil PSI.
10psi for every 1k rpm'sLast edited by JustAddDirt; 06-05-2013, 09:43 AM.I think there should be lifeguards in the genepool.
Originally posted by JustAddDirt View PostWhat brand is the pan, and pickup? I have heard of this with cheap pans, and not many trap doors, and baffeling to control oil slosh.
all good stuff, what brand pan are you using.? Also just my two cents but what weight oil are you using..going to a straight 30wt should help psi as well.
