What is the advantage of the low-pressure, base-valve, monotube shock vs a twin-tube of the same valving when on the slick? It used to be that you ran gas shocks on the tack or rough, and twin-tubes on the slick. What changed, and why?
Are they best suited to be run together (all gas, or all twin-tube) or is there an advantage to having a certain type on a certain corner?
Is it just a way to get you to buy the $250-$350 monotube vs the $150-$180 twin-tube?
FWIW: I run IMCA rules, so no schrader valve (no pressure adjustments in the pits).
