biscuit pull bar mounting direction? and spacing at housing
  • dukesracin
    • Jun 2010
    • 50
    I have a shaw mod with the shaw biscuit pull bar.
    Does it matter which end I connect to the chassis? Brake side or pull side?
    This wishbone style bar looks like it doesn't matter which way it is oriented, just wondering if it really matters?
    I have been running it centered over the rearend - how can I use the mounting position over the rearend to tune, i.e., move to left or center =???? vs. move to right of center =????
    Thanks
  • washeduptoo
    • 1353
    Moving it closer to a tire will load that tire more. Good luck.
    • dukesracin
      • Jun 2010
      • 50
      Thanks, so I guess it doesn't matter which direction it is installed?
      • washeduptoo
        • 1353
        Not familiar with your bar but the ones we have run, it didn't matter, but call Shaw for the correct information. Good luck.
