LR brake floater
  • LateModel B23
    • Oct 2012
    • 283
    LR brake floater
    This is on a 2009 Shaw 4 four bar. The LR brake is floated, what happens, if any thing, if it is clamped to the tube like a late model?
  • Confused?
    • Apr 2009
    • 418
    It takes the braking forces away from the chassis and puts them into the pull bar. That's the main affect. How it affects your car depends on your driving style.
    • LateModel B23
      • Oct 2012
      • 283
      Thanks, we had one "cam over" last night. Reading some old threads I see where that is due to the rod being to short. Just trying to decide on how I want to repair it - new clamp bracket or floater with correct length bar.
      • LateModel B23
        • Oct 2012
        • 283
        Is it best that the rod on the floater be 2" longer than the upper 4 link bar?
        • Confused?
          • Apr 2009
          • 418
          The top of the floater must be behind the top of the birdcage. When the LR is at full extension, the brake floater should still be behind the centerline of the axle. Use whatever length tube that is necessary. Id the brake floater can get to the centerline of the axle, it can go past it and tear up lots of stuff.
          • LateModel B23
            • Oct 2012
            • 283
            Okay - Thanks for the help. It appears that a 18" bar will be keep it as you suggest.
