dirtworks rear end centering
  • Duckhnter83
    • Apr 2013
    • 152
    Can someone tell me how dirrworks centers their rear end? Measurements, from where, how? I know BMS uses q measurement from the brake rotor to the pan hard/jbar support. Does dirtworks have something as simple? Thanks in advance
  • modracr41
    • Oct 2007
    • 243
    You drop a plumb bob from the right frame rail by either the welded notch or the punch mark, then you measure to the center of the pinion. That measurement should be 16 1/4". It's on the Dirtworks website under tech, then in the setup sheets, page 4. Hope this helps.
