Purging P/S of air
  • washeduptoo
    • 1353
    Purging P/S of air
    Is there a fail proof way of purging the air from a p/s system, would loosen a fitting work? Its a rear mounted tandem pump with all the hoses, brand new and brand new 12-1 Sweet steering box.Thanks
  • HEAVY DUTY
    • 796
    Just take the lid off the tank and turn the steering box back and forth all the way from one side to the other.It is better to do it with the drag link unhooked so the steering box can go all the way to its internal stops.The air bubbles will go to the can and dissapate. The engine does not have to be running.
    • washeduptoo
      • 1353
      Thanks Mr. Adams. That is what we thought but it all seems stiff and I was thinking it might be air. Didn't try the unhooked part though, might need to go down the dirt road to see if it will loosen up some. Thanks again.
      • powerslide
        • 2696
        may have to bring it up to about 2500 rpm if its a kse pump
        • washeduptoo
          • 1353
          Thanks will try that. Will the steering be stiff at idle with these pumps and at higher rpm turn smooth? Haven't been out of the shop yet with the weather down here the last week.Thanks
          • mcveyracing
            • 165
            We run a KRC pump off the bellhousing and it felt very stiff at low RPM's, almost like there was no power assist at all. The KRC pumps have a change-able flow fitting that can be changed to make it easier or harder to turn. So we bumped it up one size and it made it a bit easier at low RPM without being too easy at speed.
            • powerslide
              • 2696
              yes almost like no power steering in pits and idling. this is compunded when running the 605 box
              • washeduptoo
                • 1353
                Thanks for the suggestions, I will pass these along. Thanks again.
                • washeduptoo
                  • 1353
                  Well, we tried the unhooking the pitman and turned it to internals stops, didn't help. Tried over 2500 rpm in shop, didn't help. Finally the weather let us get it outside on the dirt road and turned it pretty good, that didn't help. It must not be air or the rpm. I guess we'll put the old steering box on to elimate that and go from there. Anyone have any trouble with the sweet steering 12-1 with a quickner? We have the hose to the pump running down hill without a swag in the hoses. Any more ideas, does anyone know what pressures these pumps are suppose to put out(it looks to be working). Guess we'll have to give Sweet and KSE a call Monday to see what they say. Thanks
                  • HEAVY DUTY
                    • 796
                    If it is stiff at low RPM and gets easier as the RPM goes up ,it is a volume problem.The quicker the steering the more volume of fluid is needed. sweet makes a high volume pump for a steering quickener application that helps the low RPM stiffness.
                    • washeduptoo
                      • 1353
                      I was looking at there site and saw that when using a steering quickner it has to run a different valving of .2 or the .185. Our chassis builder is the one who ordered it for us, not sure what valve it is. Not at the shop where car is, is there a number on the box that will tell us what valve it is. I saw on the site has a number, not sure if its on box or not. Thanks Mr. Adams.
                      • not clamped up
                        • 287
                        Stephen,
                        I ran into this problem earlier this year first time its ever happened and I don't know if its your problem,but here goes: somehow the quickener got full of water which made a greasy muddy mess,we was lucky to find the problem because we were setting the frontend,when the motors running its hard to here the bearings making noise and we just assumed it was a little stiff because of being new,anyway the water got in there and made rust on the bearings and a think mud paste,after ordering new bearings we just kept on cleaning on it and after 4 hrs got it working like its suppose to,like I said don't know if thats your problem but it only takes a couple of minutes to take it apart and check it and that is the first time i've ever had a problem like that with a quickner.
                        Dave
                        • washeduptoo
                          • 1353
                          Thanks for the suggestion. Its a new quickner also, everything is brand new. All new front end parts, ball jts,lowers, uppers,new steering box, new shaft, new quickner, new tandem pump. That is why everything is so confusing and all I can think of now is like Mr. Adams said and its the wrong valve to use with the quickner. I went and got the numbers off the box and will call Monday to see what Sweet says. From the numbers on the box, all I know is its a 12-1 box. lol
                          Thanks Dave, you helping someone this season?
                          • cullen17racing
                            • Aug 2010
                            • 12
                            quickner mounting
                            another thing to check is the mounting of the quickner. i too had a similar problem and it ended up being the quickner, and how it was mounted put it in some sort of a bind. i was able to tweak the mounting bracket and fixed the problem. i would run the car and loosen the quickner bolts to see if it is that simple! i was surprised myself. and please note i changed the krc valve first thinking the same as others here! hope this helps
                            • washeduptoo
                              • 1353
                              Will check that tomorrow, thanks for the suggestion.
