Sportmod dry slick
  • slim269
    • Jun 2013
    • 36
    Sportmod dry slick
    Question on weight percentages in rear on dry slick runnning 53.9 percent in rear withf 80 lbs of bite will less rear percentage help if i lower bite number TRYING TO GET MORE FORWARD BITE
  • slim269
    • Jun 2013
    • 36
    To add to this spring rates rt frt 650 lf 600 lr 250 rr 195
    • lilsumo
      • Jul 2011
      • 154
      "will less rear percentage help if i lower bite number"
      Not being a smart a$$, but help with what?
      • slim269
        • Jun 2013
        • 36
        Trying to get more forward bite on dry slick i have some lead i can remove to bring it down to 52.5
        • speedbuggy
          • 259
          I would think you would want MORE rear % and MORE bite.
          Why are you trying to go the other way?
          I run 57% rear and 180# of bite.
          If it starts getting tight in the center, then add more LR bar angle.
          • modracr41
            • Oct 2007
            • 243
            I run a WT Harris UMP modified, and it has a little different rear set up. We run a half-leaf on the rear with a solid pull-bar connected to a reece bar but set-up wise, it's a 3-link. Speedbuggy's right about adding rear % to increase fwd bite (full of fuel my car is close to 60% rear) but to loosen the car from the middle off I add more RR bar angle. That increases thrust angle, and adds more RR traction which will loosen the car off the corner. And remember, it's better to correct a condition by adding traction (more RR bar angle) than removing traction (less LR angle). Just my 2 cents. Good luck!
            • slim269
              • Jun 2013
              • 36
              Thanks for help set it at 56.5% rear 110 bite changed rear springs to 225 lr and 175 rr let you know how it works
              • racinjj
                • 98
                With the limited power of the sportmods I dont recommend going much more with the rear % than what you have or your turn in will suffer. Your spring change and increased bite will definitely help.
                www.UltimateRaceCars.com
                • slim269
                  • Jun 2013
                  • 36
                  Well to tight coming in to tight in middle have some more work to do
                  • speedbuggy
                    • 259
                    Add some more bite and increase RR bar angle.
                    Did drive off improve?
                    • modracr41
                      • Oct 2007
                      • 243
                      Try increasing RF spring rate and raising RR trailing arm 1". Good luck.
                      • slim269
                        • Jun 2013
                        • 36
                        Yes it improved drive off but it was to tight coming in and real tight in middle just when you want to get on gas had death push in middle
                        • modracr41
                          • Oct 2007
                          • 243
                          Ok, you need to look to make sure you don't have something binding like a shock. It sounds like the car isn't transferring on entry. A binding shock on RF or LR can cause this. Take the shocks off and run them all the way through the travel looking for a sticky spot. Visually inspect the outside of the tubes to check for dents. I had a shock cause me grief this way once and the dent was real small. If you don't find anything there, put the car on jack stands, with the shocks disconnected and run the suspension through the travel to make sure there's no binding. If you still find nothing, increase the RF spring by 25#. This will help turn in and the middle. Good luck.
