pullbar location on rearend
  • Flyin Iowan
    • 558
    When a car is in full travel should the pullbar on the rearend go behind centerline or should it stay in front?
    Thanks
    Chris Zogg
  • CsR41
    • Aug 2010
    • 169
    The pullbar should NEVER go past the axle center line.
    • mod88s
      • 226
      Depends on where your pullbar mounts. Some have it moved forward, some back just in front of centerline, some actually start off behind the centerline. What are you trying to accomplish?
      • Flyin Iowan
        • 558
        Just looking at ways to improve bite....it starts about 2" ahead. Going to put a camera on it and see how far it does travel
        Chris Zogg
        • Dirt Knife
          • Jun 2012
          • 147
          Thoughts
          Right or Wrong
          I run mine 1.5" ahead It has 2.5" to 3" travel.
          I start at 22.5* down and as it pulls thru its arc ( as it pivots about the axel centerline in the side view) it looses its angle
          to extend its pull down the strait.
          Seems to keep its bite rather than load and unload.
          J M O
          • powerslide
            • 2696
            Initial bite or bite down the straight away?
            • Flyin Iowan
              • 558
              initial, i put 3 deg more angle in it with a frame change and now it spins down the straight. so with the angle i have 16.6* its more everywhere but with less angle its initial. i like the 16.6* because it keeps the LF on the ground.
              just looking at the car and theres 3 more holes on my bracket and im wondering what it will all do
              Chris Zogg
              • mod88s
                • 226
                This is a topic that a bazillion people are going to have a bazillion different answers. What kind of chassis do you have? and have you contacted them for support? Remember, you don't need all that bite when you can get your car IN and Through the middle faster. That is the key. Its not all about bite, same thing Jason hughes told me.
