Rearend Question
  • 4coil
    • 105
    Rearend Question
    When switching over from a 9" rear to a quick change, does the car act differently? If so please give particulars about what you have experienced. This is on a 3-link set-up with pullbar and solid mounted lower arms. Thank you in advance for any replies................
  • 7uptruckracer
    • May 2009
    • 1336
    No really the quickchange can unless you really get the low drag stuff kill more HP. The Pinion static height is different between the two so you have to compensate with your static pinion mount on the Jbar. other then that if all your shocks and bars arm mounted in the comparable locations there isn't really a difference
    • JustAddDirt
      • 1893
      9" drives off the LR
      QC drives off the RR
      have to add a smidge more wedge to compensate
      Pinion is about 2" lower on QC. generally you have to move back of motor down a bit to correct driveshaft angle.
      • 7uptruckracer
        • May 2009
        • 1336
        This I have to hear. A spool Is a spool and locker is a locker they don't know what they are in....someone fell asleep in physics class......
        • JustAddDirt
          • 1893
          It has to do with the direction of force (downward pressure) applied to tire when the pinion gear tries to climb the ring gear. Torque
          On a 9" rear, or any conventional style axle, there is more pressure applied to the LR wheel on acceleration.
          Which is why on an open rear end, you punch the throttle to accelerate in a straight line, the RR wheel spins, even though motor torque tries to twist chassis and plant RR, it still unloads the RR tire.
          that is why a lot of drag racers add their battery to the right rear corner of their vehicle.
          On a qc, the pinion is on the back side of the axle, and on the opposite side of ring gear, so the torque applied when pinion tries to climb the ring gear more pressure is applied to the RR wheel.
          It has nothing to do with lockers, or spools.
          It has to do with torque, and the directional forces in which items react when power, or rotation is applied.
          That is why you have to add a bit of wedge to compensate, typically I add about 25lbs on a 4 link car.
          Just my opinion.
          • bittight
            • Jun 2009
            • 358
            Mark Bush talks a little about it and I believe Steve smith does to, it's no opinion, guess u wasnt asleep in physics lol.
            • Mosidebite
              • 717
              Some people...thanks to those who provide real and understandable responses to questions.
              • JetSpeed22
                • Oct 2009
                • 28
                Just my opinion.
                Thank you Dr. Sheldon Cooper for your physics lesson. Your theories on mechanical quantum physics & string theory is enlightening.
                Knock Knock Penny! Knock Knock Penny! Knock Knock Penny!
                • MEB4U
                  • Aug 2007
                  • 77
                  And I just thought all he could do is drive!!!!!
                  ImBored
                  • 7uptruckracer
                    • May 2009
                    • 1336
                    This is the first I've heard of this and if you run a spool or locker you can't bust one tire loose without the other so what's the true difference? We are loading the cars through bar angles and springs to control dynamic weight transfer and thrust angles and this pertains to neither so for all PRACTICAL purposes if he mounts all his bars at the same toe angles and static angles and distance away from axle centerline he should be fine. I've never talked to a manufacturer on a modified where its commons to see both rear ends and see them list or ask which one your running so they can dial you in. Mark has never even mentioned this stuff to me, in the ever changing traction world of dirt keep it simple.
                    • 7uptruckracer
                      • May 2009
                      • 1336
                      I'm pretty sure your not meaning to say the whole balance of force is different LR to RR MAYBE slightly toward one way more then the other which that might be true it's not really even worth mentioning unless he's going to be drag racing especially when you're also suggesting he move his motor down which most you can't just "tilt" the motor back with central block mounts and midplates you can really only raise and lower which would be a significant change I've played with before trying to get my shaft height right and that also is not a compromise to make with that weight drop it in see what you feel and go from there
                      • JetSpeed22
                        • Oct 2009
                        • 28
                        I think if you go back and ready what JustAddDirt said, you would see that he said you generally have to move "the back of Motor down a bit" From where Im from that's the same thing as tilting. Didn't see anywhere in his post where he suggested to move the whole motor down.
                        Looks like someone fell asleep during reading time....
                        • 7uptruckracer
                          • May 2009
                          • 1336
                          Yes and I said the motors with midplates you can't just tilt the motor didnt I? By this theory it should also unload the RR on decel too correct so adding bite would just be a compromise
                          • JustAddDirt
                            • 1893
                            Yes, you can adjust height at mid-plate, if your mid-plate has multiple holes for height. My chassis builder has 2 holes in the mid-plate just for the type of rearend used.
                            top hole QC
                            bottom hole 9"
                            And yes before you say it, it does twist the front motor mounts just a tick. But car does not know it, nor does motor.
                            I guess 7uptruckracer, we can just agree to disagree here. I am not here to get into a pissing contest, just trying to help a guy out with his question.
                            • Leeracing40
                              • 415
                              Anyone have a link to support the rotational forces acting upon the rear end? You would still have the rotational force on the thru shaft in a quickchange, which would be the same as the pinion acting on a 9". I would think if you vectored all the rotational forces from one to the other there would be much of a difference. You still have the drive line in, and the tires to the ground.
