Can someone explain how moving each trailing arm on a 2 link would effect the handling of the car? Like if I raised the left bar up what should I expect? tighten the car loosen the car and where at entry, exit? If i lowered it? How about the right? Any input would be great as I can't find much in this
2 link question
Usually the left is for exit and right side for entry, but not always true. If you raise lr usually increase drive, lowering opposite can happen, lose drive. Raise the rr usually loosen entry, lowering rr opposite occurs, tightens entry. Like I said that is what usually happens but not always true. Best of luck.
