UMP lower control arm rule
  • Wheelman33
    • Apr 2008
    • 232
    Rule book says as of 1-1-14 only stock ump approved lowers. Had a guy tell me they have been putting this in the rule book every year and not enforcing it. Anybody have any input on this?
    Dont want to spend the $ on aftermarket lowers and not be able to use them.
  • beaver396
    • Aug 2007
    • 103
    car builders, at least the one I buy from has to send a set of tubular lowers to UMP to be approved. so it doesn't necessarily have to be stock but must be approved. once approved the car builder agrees not to alter. Really what is comes down to is the $10 sticker that's put on them.
    • umpmod15
      • 68
      P.) Alterations and/or relocation of the lower A-frames will not be permitted. DIRTcar approved after-market
      lower control arms, which are mounted in the OEM location and maintaining the OEM Manufacturer will be
      permitted. All after-market lower control arms must have an official DIRTcar-approved and numbered decal
      displayed for ease of inspection at all times.
      • BPRC MAN
        • Apr 2012
        • 156
        i wish they would go to stock lowers or at least not let everyone run ford lowers on a metric front car.
        • MacNoodle
          • Jun 2009
          • 138
          What is the difference in that and a metric running nova lowers?
          • jsf74
            • 544
            Huge difference
            • rdracer00
              • 433
              Who cares. Get rid of the stupid front clips all together! Easier to build and fix and cheaper. Have a track width rule and race!
              • MacNoodle
                • Jun 2009
                • 138
                So where do you draw the line? Why is it ok for someone to put Nova lowers on a metric that are not meant for that clip, but another guy can't run fords on his metric clip? At the end of the day both guys are running lowers that are not meant for that particular clip right? Then you have the chevelle clips that come in a dozen pieces that make it a lot easier and less noticeable to cheat up... I'm all for the tubular clips! I think it "should" be cheaper and easier to repair. Theses old metric frames are getting hard to find anymore.... Something is going to have to happen eventually or we will all be running chevelle clips in the future do to them being remanufactured. I think these chassis builders starting to use the ford clips are on the right track for now.... But eventually they will dry up too. There is just to much (not a nice word)(not a nice word)(not a nice word)(not a nice word) time and work involved in prepping these factory clips for the jig.
                • Racer111
                  • 796
                  They should use the LM bare chassis but with all the mod rules .
                  • jbh25
                    • 259
                    What ford lowers fit metric clip
                    • HEAVY DUTY
                      • 796
                      I agree with the fabricated clips , but one thing about using late model frames is that they have rack and pinions. They don't have places for steering boxes, and are not the right width for steering and drag links. I don't think we want to be banging wheels with steel wheels and small tires with rack and pinions. I havnt raced a late model since 87 when we had racks with no power steering, and my wrists still hurts from it. That was with big ole marshmellow tires that cushioned the steering feedback.
                      • 7uptruckracer
                        Ford LTD (Big Ford) fit JBH25 its like an 18" arm a lot do it for trackwidth
                        • jbh25
                          • 259
                          7uptruckracer they will fit on the small 80s model metrics
                          • racin6mod
                            • 2172
                            some run a ford ltd right front and a Camaro lf. you have to move the right lower mount(which is bending the he11 out of the rule). this class was designed so guys could go to the junkyard for parts you could mix and match what ever you wanted I rather take a step back to that than go the way of the latemodel. which around here is pretty much dead. we have moved to fare in that direction already.
                            • JHobbs26
                              • Aug 2007
                              • 146
                              has anyone run the lowers from UB Machine? Curious how well they hold up, for a fabricated lower the price seems pretty decent......
                              UB Machine has been serving the racing industry for nearly 50 years!
